ACADIA 3hp DRIP OILER NEEDED??
Old Marine Engine » Acadia » ACADIA 3hp DRIP OILER NEEDED?? « Previous Next »
Eric McKenna
Username: engineguy63
Posted on Friday, September 06, 2013 - 02:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
OK Guys , Bought My first marine engine....I am a farm engine collector. I am a little amazed at the simplicity of these hard working engines....I am sure I will acquire more of them. I do not seam to see an area where a drip oiler would go to lubricate the wrist pin, piston, cylinder wall etc. I do see a pipe thread inlet on the air valve between the carb (schebler) and the crankcase....Could this be it? Thanks for any and all help!
Post Number: 1725
Posted on Friday, September 06, 2013 - 07:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Eric,
You are correct on the pipe thread. However the best way to run the engine on simply premix the gas and oil.
Where in Mass?
I am on Taunton and most likely have what you need
