novophil
New member Username: novophil
Post Number: 1 Registered: 01-2013
| Posted on Thursday, January 24, 2013 - 08:59 pm: |
I acquired a bukh dv10 and need to replace the impeller. It has a screw in the middle, but unlike most modern pump the shaft has a threaded hole to secure the impeller with the screw. The problem is that to remove the impeller i need to unscrew the screw, but do not have access to it in between the impeller wings" So short of removing the entire water pump, what can i do? Thanks Phil |
