Bukh westerbeke dv10 impeller issue
Old Marine Engine » Diesel Inboards » Bukh westerbeke dv10 impeller issue « Previous Next »
novophil
Username: novophil
Posted on Thursday, January 24, 2013 - 08:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I acquired a bukh dv10 and need to replace the impeller.
It has a screw in the middle, but unlike most modern pump the shaft has a threaded hole to secure the impeller with the screw.
The problem is that to remove the impeller i need to unscrew the screw, but do not have access to it in between the impeller wings"
So short of removing the entire water pump, what can i do?
Phil
