Zenith Carburetor
Old Marine Engine » Multi Cylinder Gas Inboards » Zenith Carburetor « Previous Next »
gonzo
Username: gonzo
Post Number: 26
Posted on Thursday, January 12, 2012 - 08:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am trying to find the float level specs on a zenith carburetor. It was on a 1951 Hercules in a Chris Craft. The upper casting says: AR2 45, 3212, 9776B and the lower: B175 13.
drrot
Username: drrot
Post Number: 115
Posted on Friday, January 13, 2012 - 07:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
2 25/64" +- 3/64"
gonzo
Username: gonzo
Post Number: 27
Posted on Thursday, January 19, 2012 - 03:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks, I assume that is to the bottom of the float with the gasket on.
drrot
Username: drrot
Post Number: 116
Posted on Friday, January 20, 2012 - 06:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
upside down from carb to top of float (bottom) without gasket
Randy Bass
Posted on Friday, January 11, 2013 - 04:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have two newly rebuilt (professionally) carbs from an old 36 ft Chris Craft with twin herculess engines. AR2-45 stamped on them, with flame arrestors. Would like to sell, or info on value.
