Crank grinder
Old Marine Engine » One and Two Cylinder Gas Inboards » Crank grinder « Previous Next »
Post Number: 739
Posted on Sunday, December 02, 2012 - 09:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I bought a crankshaft grinder in the spring, finally got to try it. Below is a link to the story on Harry's Page, it's a pain reducing all of the pictures.
http://www.smokstak.com/forum/showthread.php?t=112752
rbprice
Username: rbprice
Post Number: 411
Posted on Monday, December 03, 2012 - 07:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
JB- did you completely fill the old keyway and then grind and re-mill the keyway?
As usual, a wonderful workman like job.
Thanks for sharing.
Post Number: 740
Posted on Monday, December 03, 2012 - 07:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bob, first I welded in the keyways, then I put it in the lathe and took a light cut so everything was running true. Next step was to weld it, I did the flywheel area first, machined it true, then welded the mains and over the flywheel area. It filled in well, no voids. The keyways will have to be recut.
johnny
Username: johnny
Post Number: 445
Posted on Wednesday, December 05, 2012 - 11:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
JB, After you welded and grind the crank how straight did your mains and con-rod journal come out? Have much trouble with the crank moving due to stress from all the welding or did you do annealing of some kind after you roughed it?
Post Number: 741
Posted on Wednesday, December 05, 2012 - 05:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
THe cranks I've welded seem to be stable. These old shafts are fairly soft, I would compare them to cold roll. When you straighten one it doesn't take much over correction to get it right, they aren't springy. When welding I use the mig with 70,000 psi wire, I believe this is harder than the shaft but it's called mild steel. I was told it blends with the base metal and comes in somewhere between. The crank turns red while welding, I let it cool naturally, it machines well in the lathe. I've found that if you come back and touch up a spot it will cool fast and be hard, obvious when rough turning in the lathe. Some of the guys with the Dispros had cranks weklded at a crank shop, they all broke. My guess is that they used a hard material, the soft base metal flexed, the hard metal cracked and migrated on through.
Post Number: 641
Posted on Wednesday, December 05, 2012 - 09:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The copper jacket Dispro engine cranks that were built up with flame spraying all ( or all that I know of) broke with a cone shaped fracture. That was after they had been running for a while (hours)
under full load. I suspect that if they were only show engines and run with no load, they might take a while to fracture - but they would fracture eventually.
The technique now is to have them chrome plated up and then ground to finish dimension. The plating shop can do up to about 75-80 thou.
Post Number: 743
Posted on Friday, December 07, 2012 - 08:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Finished another one. This is for a YT-1. Dick Day sent it to a local crank shop, they didn't realize it was sleeve bearings, only ground the main area, no way to slip a .010" under bearing over the standard ends. I welded it, roughed it in in the lathe and ground it standard. Looks like it should work. cs
richardday
Post Number: 1034
Posted on Saturday, December 08, 2012 - 01:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Beautiful job. Thank you so much Dick
