Frank Williams
| Posted on Tuesday, May 24, 2005 - 02:31 pm: |
Need information on finding manuals and parts, valves,springs,rings,gaskets,etc. |
antique_marine_ptk
New member Username: antique_marine_ptk
Post Number: 2 Registered: 03-2005
| Posted on Tuesday, May 24, 2005 - 09:15 pm: |
We have everything that you require for your engine. We can be contacted via email [email protected] or by phone 905-831-2370. Patrick, Antique Marine. |
jamesosler
| Posted on Tuesday, May 24, 2005 - 09:23 pm: |
Is the ZXB block marineized and if so what company did it. I have the manual for the Buchanan Midget which is based on the ZXB Block. For parts call Parry Automotive in Orillia Ontario. Or you can try antiquemarine.com James |
geelee
New member Username: geelee
Post Number: 1 Registered: 04-2007
| Posted on Sunday, October 05, 2008 - 05:38 pm: |
I have a ZXB 4 cylinder that was for a marine application. I have mounted it on a small trailer with a radiator and fan that I have to run off a battery as the Hercules ZXB uses a magneto for ignition. I cleaned it up and it runs like new. Copper fittings on the water lines. It was in a farm orchard sprayer (Used a cooling line in the spray mix) and the guy said that his father only used it 10 hours before the pump died. It was a 500 gallon wooden tank. But too poisonous to reuse Motor Serial number is 1147347 Piston 2 5/8 x 3 Anyone have a good guess as to the age or value of said motor? |
larry_from_maryland
Post Number: 320 Registered: 07-2003
| Posted on Sunday, October 05, 2008 - 07:25 pm: |
That engine was used in the avery and moline model V tractor. This was not a real popular tractor, but most of ones you see either have a bad engine or no engine at all. The tractor was made from the 40's till about 1955. Most of these engines had either a casting date cast into the block or have a stamped date on the right side just above the oil pan. I have not seen a good engine like this sell ever. I would think its worth several hundered and up because they are hard to find. You could advertise it on www.ytmag.com or ask what it might be worth. |
Noahfields
| Posted on Thursday, December 13, 2012 - 12:06 pm: |
Hello, we have a zxb motor that we are trying to get running for a shopclass project and are having problems getting it running, any suggestions about how to wire it or maybe get it running? |
larry_from_maryland
Post Number: 514 Registered: 07-2003
| Posted on Thursday, December 13, 2012 - 07:37 pm: |
Fireing order is 1243 and the front is number 1. |
