Gray Marine Phantom 6-93
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Marine Phantom 6-93 « Previous Next »
John Roesch
Posted on Sunday, September 28, 2003 - 07:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have just aquired a 1933 Lyman 19' 3 cocckpit runabout. Original engine was said to be a Gray Phantom 6-93. No engine currently in boat. Have found a Gray Phantom 6-135 for sale. Anyone know of any diffences in dimensions and weight between the two.
Posted on Sunday, September 28, 2003 - 09:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
John,
Are your sure it was a Phantom 6-93 ?
I don't see that in the indexes of Gray engines. There was a Phantom Six-90 and a Phantom Six-103.
Six-135
  • 6 cylinder
  • 3-7/16 x 4-3/8 244cid
  • Weight, Iron: direct drive 800 lbs , reduc 900lbs
  • 135HP @ 3600RPM
No1SpeedSkiff
Posted on Monday, October 27, 2003 - 11:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
John,
My 1934 literature shows a "Phantom 6-93" as a "Hi-Speed" engine, one model down from their "Racing" model. It was rated 93 HP. at 3600 rpm., 3 3/8" X 4", 214 cu. in., weight of 686 lbs. with an alum. oil pan. I would have to know what year 6-135 in order to compare dimensions.
craig
Posted on Saturday, February 19, 2005 - 07:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i think i have the motor you need. it is a 6-135 i got the engine from a demolition sale it was in the process of being rebuilt by the man who owned the house but has since passed away. the engine has new piston and rods.the crank was worked, and the head was done it is assembled less the oil pan and exhaust manifold witch i also have. there is a transmisson attatched to the block. there is two zenith carbs in the box of parts also .i have a prop shaft and rudder gear box. there is also some misc. parts i cannot identify. the engine came out of a 1950 somthing century that the man was rebuilding that did not survive the demo. e-mail me if you think it would be of use to you or somebody you know.
Jamie
Posted on Monday, February 28, 2005 - 12:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Craig,
I might be interested in your Graymarine 135 HP. Please let me know. You can call me at 315-554-4045.
LDESHON
Posted on Friday, April 21, 2006 - 09:38 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have a Grays Marine Continental F135 engine that was donated to a nonprofit. It is supposedly completely rebuilt. We need to sell. Can you give me any ifno. Is it 4 cylinder? Gas?
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 146
Posted on Friday, April 21, 2006 - 12:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yes its a 4 cylinder gas.You seem to be missing the sprakplugs and distributor.The model engine is probably f140 or f162,they are both the same size outside only they have differant pistons inside.A picture of the other side would show if you are missing all the electics.
Tom F
Posted on Saturday, August 11, 2012 - 08:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Gray Marine Phantom 6-93 and would like to get another. Does anyone have one around for sale?
Gary W.
Posted on Wednesday, August 29, 2012 - 07:46 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Gray Marine Model 100 and a Gray Marine Phantom six-104 for sale. Both need to be rebuilt.
brad schmidt
Username: watercraft
Posted on Friday, November 30, 2012 - 10:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a phantom 6-112 serial 301036
