Gray 4-75 Identification
Old Marine Engine » Multi Cylinder Gas Inboards » Gray 4-75 Identification « Previous Next »
britishautospecialty
Username: britishautospecialty
Posted on Monday, December 10, 2012 - 08:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have obtained a Gray 4-75 that supposedly came from a 1950s Chris Craft, which is long gone. The engine includes the raw water pump, updraft carburetor, fuel pump, flywheel, starter, etc and it appears to be essentially complete. Has a transmission also. Serial number is C2370 on the brass label. Any help with identifying it to when it was made is appreciated. It is not an engine I would use, so if someone has use for it, let me know. Regards, George
bruce
Username: bruce
Post Number: 345
Posted on Tuesday, December 11, 2012 - 11:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
George, Your Gray appears to be a mid year 1941 model
Posted on Tuesday, December 11, 2012 - 02:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks, I appreciate the help!
