Ceased shaft
Old Marine Engine » Gears, Transmissions, and Propellers » Ceased shaft « Previous Next »
Phillip Weeks
Username: phillip
Posted on Thursday, September 13, 2012 - 10:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have a 6 ft.x 7/8 dia shaft with a variable pitch prop that is ceased.Brass inner shaft ceased to ss outer shaft. Prop also ceased to shaft.Anyone have an easy process to seperate these frozen parts to make a working unit.
jerome blumberg
Username: jerome
Post Number: 7
Posted on Friday, September 14, 2012 - 02:37 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If ex-owner shifted to a transmission it is more likely that he blocked the variable pitch on purpose so he probably put a pin somewhere on the shaft to lock it, you have to find it and remove it..
