The FM 3.
Old Marine Engine » Multi Cylinder Gas Inboards » The FM 3. « Previous Next »
Post Number: 537
Posted on Friday, August 10, 2012 - 08:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is the FM 3 cylinder I have had for about 10 years.
Here is the parts motor I just picked up.
and here is what it will look like when done.
bgoss
Username: bgoss
Post Number: 179
Posted on Monday, August 13, 2012 - 07:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bill - Keep in touch as you pull it apart. We are in need of a few parts as well. First and foremost is a piston and rod if yours is the same size as this one.
fm1
fm2
Post Number: 540
Posted on Saturday, September 08, 2012 - 01:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is the bad side.
