Universal unimite four
Old Marine Engine » Multi Cylinder Gas Inboards » Universal unimite four « Previous Next »
codraro
Username: codraro
Posted on Sunday, August 12, 2012 - 07:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for engine shims for adjusting engine to shaft
Does anyone know where to find these wedges
Thanks Kevin Codraro
gonzo
Username: gonzo
Post Number: 36
Posted on Sunday, August 19, 2012 - 10:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Are you looking for the shims that look like sheet metal or the wedges with a slot?
codraro
Username: codraro
Posted on Tuesday, August 21, 2012 - 09:01 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
looking for wedges with slots
rbprice
Username: rbprice
Post Number: 395
Posted on Tuesday, August 21, 2012 - 10:33 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If you are in the US Kevin, then McMaster-Carr has them in stock. See
http://www.mcmaster.com/#slotted-shims/=iy22wq
Post Number: 1554
Posted on Tuesday, August 21, 2012 - 06:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The old timers made them from hardwood. I remember my Dad making them out of Oak.
Hope this helps
codraro
Username: codraro
Posted on Tuesday, August 21, 2012 - 06:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yesterday
I found the wedges with slots
I tried making them from wana but I was not happy
they probably would have worked but I did not want to get in deep with the engine install and have to stop and make another wedge with a slot
These are made of metal
