Post Number: 750 Registered: 01-2002
| Posted on Monday, November 05, 2007 - 06:11 pm: |
Here are some pics of my latest project. It's tag was missing so I don't know the year. However it is a late early style engine. We know that due to the following: 3 port and no place for the earlier 2 port intake in the crankcase Plug is on the top of the cylinder not the side Cuno timer 2 bolt water pump. This is what sets it in the early style bunch. This puts it about ca 1915 Note the weld on the cylinder in the first pic
Post Number: 751 Registered: 01-2002
| Posted on Monday, November 05, 2007 - 06:33 pm: |
It is completly apart and on the way to running again. The water jacket was completly full of rust. However it all broke up and came out easily. The crack had been welded with stainless and it didn't stick well. I peeled it off and v'd out the crack to use epoxy. Pics of the cylinder ready for epoxy.
Post Number: 753 Registered: 01-2002
| Posted on Tuesday, November 06, 2007 - 05:32 pm: |
Epoxy water jacket repair
Post Number: 310 Registered: 07-2002
| Posted on Tuesday, November 06, 2007 - 10:41 pm: |
Looks good Ernie, what epoxy are you using? |
Post Number: 754 Registered: 01-2002
| Posted on Wednesday, November 07, 2007 - 07:43 am: |
JB, If it isn't strural I use some called PC7 that I get from Home Depot. It is thixotropic meaning it doesn't run or sag. If I am concerned with strength I use good old JB weld. The slow kind. So to fill cracks and replace part of a water jacket I use PC7. To glue in pieces of water jacket I use JB weld |
Post Number: 539 Registered: 11-2003
| Posted on Wednesday, November 07, 2007 - 07:50 pm: |
Ernie, Nice job but how do you support the inside of the water jacket? |
Post Number: 755 Registered: 01-2002
| Posted on Thursday, November 08, 2007 - 06:04 pm: |
Styrofoam then pour gasoline in the waterjacket |
Post Number: 756 Registered: 01-2002
| Posted on Saturday, November 10, 2007 - 06:08 pm: |
Cylinder with jewlery. I need to polish them and paint the intake, exhaust and water outlet flanges. The tag on the left is instructions for mixing gas and oil
Robert
Post Number: 182 Registered: 07-2003
| Posted on Sunday, November 11, 2007 - 01:06 pm: |
Looks very nice; a fresh water engine? Will it be a runner or display only? |
Post Number: 757 Registered: 01-2002
| Posted on Sunday, November 11, 2007 - 01:45 pm: |
It will be a runner. It will take a bit to get the rest of it painted and put together. |
Post Number: 811 Registered: 01-2002
| Posted on Sunday, May 04, 2008 - 02:41 pm: |
Getting it's Calvert clothes on Might even have it as a runner by the weekend Copression is good Yes the flywheel will be painted...
Robert
Post Number: 216 Registered: 07-2003
| Posted on Sunday, May 04, 2008 - 03:31 pm: |
You make it look easy Ernie! Any concerns about the strength of the cylinder walls when the jacket is not 'whole'? |
Post Number: 812 Registered: 01-2002
| Posted on Sunday, May 04, 2008 - 05:53 pm: |
NO compared to the YT1 I did last year this one is like new. The YT1 runs just fine. I for sure wouldn't put in a boat but for a show engine it's been ok. |
Post Number: 813 Registered: 01-2002
| Posted on Sunday, May 04, 2008 - 06:01 pm: |
Ready to go yes...Brass polished most likely not. I plan to run it tomorrow. 1 Cent Schebler Compression Release or Exhaust gas Recirculation
Andrew Menkart
Moderator Username: andrew
Post Number: 929 Registered: 11-2001
| Posted on Sunday, May 04, 2008 - 06:58 pm: |
Looks great ! |
Post Number: 1046 Registered: 11-2003
| Posted on Tuesday, March 05, 2013 - 03:48 pm: |
Nice Job Ernie!!! |
Cay Small
Member Username: seagal007
Post Number: 18 Registered: 07-2012
| Posted on Tuesday, March 05, 2013 - 05:48 pm: |
Beautiful job. I used JB weld On the waterjackets of my old Hicks when I was commercial fishing. It worked great. |
