ISX1-450 cummins,diesel engine part I...
Old Marine Engine » Diesel Inboards » ISX1-450 cummins,diesel engine part ISX standard parts Flywh « Previous Next »
cqcummins
Username: cqcummins
Posted on Monday, August 23, 2010 - 04:41 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
ISX1-450 cummins,diesel engine part ISX standard parts Flywheel housing 3102196
ESN: 14046557Application: equipmentvehicleoilcrude oil automobilebore-[in]: 5.39Stroke-[in]: 6.65Displacement-liter[in3]: 15 [915]Cycle:6-Cylinder 4-Stroke Cylinders: 6CPL: CPL8287pump,sea water: noneLiner,Cylinder: noneFlywheel: 3680914belt: nonedrive,accessory: nonefuel consumption--L/hr[g/hr]:nonecompression ratio:noneengine length--mm[in]:noneengine width--mm[in]:noneengine height--mm[in]:noneengine Weight--(kg):noneFlywheel housing 3102196Model: ISX 400Series: ISXDATA: 2002 ISX1-450 cummins,diesel engine part ISX standard parts Flywheel housing 3102196
cylinder block
crankshaft
connrod
cylinder liner
piston
Piston pin
cylinder head
guide,valve stem
valve
valve insert
valve spring
Camshaft
main bearing
bearing connecting rod
Piston ring
Camshaft bush
nozzle,piston cooling
Repair package
Oil seal
parts catalog
repair manual
tools
belt
fuel pump
injector
filter
fuel filter
lub oil fliter
air fliter
corrosion resistor
oil
rail container crane ISX1-450 cummins diesel manifold,exhaust
lorry-mounted crane ISX1-450 cummins diesel engine manifold exhauat
creeper truck ISX1-450 diesel engine pan oil
Truck crane ISX1-450 ST2 engine lever,injector rocker
hauling truck ISX1-450 ST2 diesel heat exahanger
utility truck ISX1-450 engine exhanger,heat
tip truck ISX1-450 cummins diesel engine exchanger heat
end discharge truck mixer ISX1-450 cummins cam follower cover
railway engine ISX1-450 diesel engine cam follower and cover
pontoon crane ISX1-450 cummins diesel engine compressor,air
chain loader ISX1-450 ST2 diesel engine assembly,compressor air
mechanical loader ISX1-450 diesel air compressor
scoop loader ISX1-450 ST2 cummins diesel engine air cleaner
gas oil ISX1-450 diesel engine air cleaner
amphibian truck ISX1-450 ST2 cummins diesel engine oil pan
barge-mounted tower crane ISX1-450 cummins diesel assembly,rocker lever tla
electric loader ISX1-450 ST2 cummins accessory drive
heavy duty truck parts ISX1-450 cummins diesel engine lube oil filter
heavy duty truck parts ISX1-450 cummins oil pan
link belt type truck crane ISX1-450 cummins diesel engine aid,air heater starting
machinery equipment ISX1-450 cummins diesel engine accessory drive pueely
repair truck ISX1-450 engine air heater
Truck crane ISX1-450 cummins diesel pan oil
David Swan
Posted on Friday, August 17, 2012 - 01:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for cylinder head covers (valve covers) for 1964 model V-504-M G series Cummins marine diesel engine.
