Thornycroft RZ6 180
Old Marine Engine » Diesel Inboards » Thornycroft RZ6 180 « Previous Next »
nick_parker
Username: nick_parker
Posted on Sunday, June 20, 2010 - 04:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi, is their anyone out their that has any information on this engine. i have aquired one and do not really know anything much about it. i would really like to know tappet clearences, pipe work for gear box, fresh water and raw water cooling systems. as a lot of pipe work is missing. if any one has any paper work or diagrams for this engine would be greatly appreciated. thanks all nick.
charlie_2
Username: charlie_2
Posted on Tuesday, August 14, 2012 - 11:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm still trying to find an exploded view,of a CAV injector pump fitted to a 1976 Leyland Thorneycroft 230 marine engine,Apparently there should be two bleeding points,I have found one,and have loosened various nuts but none of which produced fuel ,Can anyone help????
Post Number: 1552
Posted on Wednesday, August 15, 2012 - 12:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Charlie,
I googled CAV injection pump and found a lot of material.
What is the model number of the pump?
charlie_2
Username: charlie_2
Posted on Friday, August 17, 2012 - 06:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Ernie,I will see if I can locate a number and get back to you,thanks again
