Twin inboard similar to gray?
Old Marine Engine » Unknown Engines - post here with photos » Twin inboard similar to gray? « Previous Next »
Nat Archer
Username: nat1kickrun
Posted on Wednesday, July 04, 2012 - 09:55 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
recently bought this engine,at first i thought it was missing most of the parts,but after piecing it together seems that only carb(top flange that goes into block has butterfly,have float arm,adj needle,needle valve,plug,another butterfly and shaft possibly a choke?,top base of carb is cast iron & has 4 screw holes for float bowl to attach),water pump,timer drive shaft are all that are missing,intake manifold is integrally cast into the engine block,has zerts on the mains,but wondering how the pistons were oiled,(oilers?,pump,or just mix oil with gas?)serial number is stamped on top of rim of flywheel and reads 55785,year,model,make,source for missing parts or pictures & dimensions on what is missing so i can make what i need,thanks,newbie to marine engines,have looked throught this site and did not find anything exactly like this(some similar,but nothing exact)
marine engine
William Schaller
Post Number: 533
Posted on Wednesday, July 04, 2012 - 12:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My first thought is Ferro.
William Schaller
Post Number: 534
Posted on Wednesday, July 04, 2012 - 12:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ferro
Bruce Hall
Username: bruce
Post Number: 311
Posted on Wednesday, July 04, 2012 - 02:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bill, Do you have a new e-mail address? the profile address doesn't seem to work..
William Schaller
Post Number: 535
Posted on Wednesday, July 04, 2012 - 03:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce, I have the same address, and it seems to be working.
Robert B. Price
Username: rbprice
Post Number: 390
Posted on Monday, August 06, 2012 - 11:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks just like the Ferro in the posting I made yesterday under the heading of Elco @ Clayton.
