Evinrude flywheel magneto
Old Marine Engine » Timers, Magnetos, Ignition » Evinrude flywheel magneto « Previous Next »
Cay Small
Username: seagal007
Posted on Tuesday, August 28, 2012 - 03:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have an Evinrude CCV motor built about 1923-24.It has been through a fire and the mag was destroyed. Do the CCV motors have the same mag as the model A rowboat motors? I would love to get this motor running. Any input would be greatly appreciated. Thanks.
Post Number: 716
Posted on Tuesday, August 28, 2012 - 07:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
your best bet would be to use the points to operate a battery ignition. If the outboards use the same ignition you may have luck finding something.
