Post Number: 1653 Registered: 01-2002
| Posted on Tuesday, May 07, 2013 - 04:51 pm: |
I suspect this would run with a carb and coil. Needs a water pump, oiler and bottom cover on the crankcase. Good compression fresh water.
Post Number: 1670 Registered: 01-2002
| Posted on Monday, May 13, 2013 - 10:41 am: |
Started it the other day. Easy start and ran good. Now on to the water pump. I see Doug K's post says counter clockwise. This one is clockwise. All a matter of how the cam is timed I suspect. I used this Loomis carb because it looked good on the engine. Darned if it didn't run good too.
Post Number: 3029 Registered: 11-2001
| Posted on Monday, May 13, 2013 - 11:00 am: |
Post Number: 3030 Registered: 11-2001
| Posted on Monday, May 13, 2013 - 11:53 am: |
* Looked at side view, bracket seems to be different, this is one of the first Dunn's mfgd so changes may have been made ?
Post Number: 1671 Registered: 01-2002
| Posted on Monday, May 13, 2013 - 03:55 pm: |
Post Number: 1691 Registered: 01-2002
| Posted on Sunday, June 23, 2013 - 03:57 pm: |
Temporary Water Pump Pump is from some 4 cylinder inboard Chain and gears are the oil pump drive from a Mazda 6 I suspect something closer to what it had will eventually show up. At least now I can run it for a longer period of time. I don't see lubrication as an issue as I can just squirt oil on it along with the rest of the stuff on the aft side of the engine
