Palmer Help
Old Marine Engine » Palmer Engine Co » Palmer Help « Previous Next »
Andrew Frears
Username: afrears
Posted on Tuesday, June 05, 2012 - 03:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Morgan 28 sailboat with a Palmer gas engine I need help getting it started Im in NY (Rockaways) any help? I need a guy to look at it and help me get it started it turns over
Eddie Ross
Username: eddie
Post Number: 295
Posted on Wednesday, June 06, 2012 - 08:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What have you tried so far ?
Andrew Frears
Username: afrears
Posted on Thursday, June 07, 2012 - 01:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Due to my near non-existant knowledge of engines I have checked that there is gas and oil and I have turned the key. I thought finding a mechanic would be easy not the impossibility that it has turned out to be.
Post Number: 695
Posted on Thursday, June 07, 2012 - 01:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Try to get in touch with Bill Roe, Roe Marine. He's in your area and dependable and honest.
Andrew Frears
Username: afrears
Posted on Thursday, June 07, 2012 - 03:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Will do thanks for the tip
Eddie Ross
Username: eddie
Post Number: 296
Posted on Thursday, June 07, 2012 - 10:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
When get a mechanic, you will probably need to dig up info for him as these engines are out of production and part sources are not easy to cross reference without help. The good news is that there is a lot of help on this board
David C. Dunbar
Username: david_in_ma
Post Number: 21
Posted on Friday, June 08, 2012 - 06:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I second JB. Bill Roe is central LI, north side. Has marine service. Have done business w/ him many times. Owns many Palmers himself. Usually displays some at Mystic in August. Can email his phone. David
Andrew Frears
Username: afrears
Posted on Wednesday, June 20, 2012 - 02:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks all for your responses. I did get a mechanic and discover that there is no pressure in one cylinder and water too. Ive been told the engine is dead. One person I thought on this thread said that they had rebuilt an engine and have it for sale. now i cant find that person. Are you out there?
