Gray marine 188 Fireball running rich...
Old Marine Engine » Multi Cylinder Gas Inboards » Gray marine 188 Fireball running rich... « Previous Next »
jtdds
Username: jtdds
Posted on Wednesday, June 20, 2012 - 05:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Boat has rich exhaust and we were not able to lean it out with any adjustments on the dual Carter carbs. Only switching the spring direction in the chokes which removed any effective choke seemed to help ( engine still cold starts fine) Any suggestions moving forward? Are the Carter's ok to have rebuilt or is there a better move?
