Volvo Penta MB 10 A Manuals etc.
Old Marine Engine » One and Two Cylinder Gas Inboards » Volvo Penta MB 10 A Manuals etc. « Previous Next »
stew
Username: stew
Posted on Monday, March 08, 2010 - 11:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello all, I recently picked up a Penta MB10A and need to do some work on it and am not finding manuals and such specific to this engine after a lot of searching. Any help would be appreciated.
Thanks, Stew.
magne
Username: magne
Posted on Tuesday, March 09, 2010 - 01:55 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Operator's manual: http://www.volvopenta.com/volvopenta/global/en-gb/marine_leisure_engines/parts_s ervice/publication_search/pages/publication_search.aspx
stew
Username: stew
Posted on Tuesday, March 09, 2010 - 10:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have tried that link and get message about damaged file. I should have... and will contact company and see if it can be fixed.
thanks again, stew
magne
Username: magne
Posted on Tuesday, March 09, 2010 - 02:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I mailed it to you, 3,6 mb pdf file.
stew
Username: stew
Posted on Tuesday, March 09, 2010 - 02:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Magne, Perfect... Printed it and will enjoy checking it out tonight.
Thank you, Stew
janblom
Posted on Wednesday, May 19, 2010 - 09:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
is there anyone who has valves for the Volvo Penta MB10A?
My e-mail is [email protected]
Thanks!
Regards, Jan}
jaydibee
Username: jaydibee
Posted on Saturday, June 26, 2010 - 10:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi.
you can get everything you need for the volvo penta mb10a at marna marine motors (the original manufactuer) at www.marna.no
I'm going to be placing an order soon. If you want to go in together, perhaps we can combine orders and get a discount
stew
Username: stew
Posted on Friday, July 16, 2010 - 10:38 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
jaydibee sorry for late response. I only need the 10 spline shaft at the rear with the flange for connecting to prop shaft and at Marna price I think I'll cobble something or have some of it made locally as engine is to be used for water pump not at sea. thanks, stew
mygooma
Username: mygooma
Posted on Monday, August 23, 2010 - 01:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am interested in rebuilding the fuel injection pump for my MD1B engine. Does anyone know if there are instructions or a manual to do the rebuild? The pump is a Bosch no. PFR1K75A380/11.
Or does anyone know where can I get the pump rebuilt?
tptplayer
Username: tptplayer
Posted on Thursday, September 20, 2012 - 09:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello: I'm new to this mess. I have a sailboat with a Volvo Penta inboard gasoline engine. The carburetor has been rebuilt twice and failed again twice. I'm told they don't make this carburetor any more. I'm also told you can get a rebuild kit at NAPA. And I"m told there's a Scandanavian company that still makes the engine. Anybody know what the real answer is?
John Bickle
Posted on Thursday, September 20, 2012 - 10:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi.
Have no fear, i have the exact same engine.
you want to go to www.marna.no using google chrome (because it enables automatic translation)
Everything is there. All manuals, all parts.
I had the same problem, but it was trivial to fix (except for the money part)
You can order a brand new carburator (i did), and installation is relatively straightforward.
If you want to deal in the states, i *highly* recommend a company called French Creek Marina.
They have ALL the parts for this engine in stock, you can get your carburator and everything there.
Dealing with Marna in Norway is a bit of a PITA, and because of the price of the Kroner, you are probably better off buying directly from French Creek Marina.
I can help you with anything else you need. The motor runs extremely well and is very, very reliable once you get the most basic stuff fixed.
John Bickle
Posted on Thursday, September 20, 2012 - 10:49 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
One more thing: I don't know if you've ever rebuilt a carburator before, but it is a fussy business. You can get the gasket from either Marna or French creek marina, but if you discover that the jet screws are warped or deformed, you are going to need a new one. I think i still kept my old carburator by accident, so if you are really desperate for parts, i suppose you could have them.
Personally, i've installed a brand new carburator and never looked back. If you can afford it, this is a way better way to go.
