Gray Marine SS-91 (X1097) 6 or 12 vol...
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Marine SS-91 (X1097) 6 or 12 volt? « Previous Next »
Jim Ferguson
Username: new_cruiser
Posted on Tuesday, April 17, 2012 - 05:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Didn't think about this earlier but does anyone know if this is a 6 volt or 12 volt system? Is there a way to tell?
Jim Staib
Username: drrot
Post Number: 121
Posted on Wednesday, April 18, 2012 - 09:07 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Easiest way is to check the ignition coil. They are usually marked. The voltage cut-out might be marked too.
Jim Ferguson
Posted on Wednesday, April 18, 2012 - 10:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you for your help. I'll be out at the boat later today and see what I can find.
