Martin
Member Username: martanke
Post Number: 4 Registered: 06-2011
| Posted on Monday, March 05, 2012 - 08:19 am: |
Does anyone know if there are conversion kits for electronic ignition available for Graymarine straight sixes with Delco distributor? /Martin |
Doug Kimball
Senior Member Username: doug11k
Post Number: 80 Registered: 12-2003
| Posted on Wednesday, March 07, 2012 - 10:24 am: |
Martin, Try this link to Pertronix Ignition http://pertronix.carshopinc.com/product_info.php/products_id/88936/1442 |
Martin
Post Number: 5 Registered: 06-2011
| Posted on Thursday, March 08, 2012 - 09:27 am: |
Thank you Doug, the link points to a conversion kit for IHC Tractor 4 Cyl. What's the relation between Graymarine and IHC tractor? |
miro forest
Senior Member Username: miro
Post Number: 606 Registered: 11-2001
| Posted on Sunday, March 11, 2012 - 08:35 am: |
There should be a plate on your distributor with a model number. The guys at Pertronix need that number to make sure you've got the right one. They make 12 V, 6 V, positive ground and negative ground versions. I found that contacting a good knowledgeable local auto parts distributor is the best approach. They can reach right into the Pertronix database. Here's the link to Pertronix http://www.pertronix.com/prod/ig/ignitor/default.aspx miro |
