TIGHT UNUSED DROFIN 12
Old Marine Engine » Diesel Inboards » TIGHT UNUSED DROFIN 12 « Previous Next »
detecta2
Username: detecta2
Posted on Saturday, July 03, 2010 - 08:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jst bought spare drofin 12 for parts, complete xcept alternater and wiring,sitting in project boat since 2003 when was fitted,reconditioned,[given 2003 reciept for parts $750.00] never started,oil gearbox and sump very clear,very hard to turn,havnt forced it yet, what should I do, how to treat this motor,might be good one day as replacement, mine is very quiet,runs fine, but at times gets very smoky, phill
noel_g
Username: noel_g
Posted on Monday, July 19, 2010 - 03:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just purchased an old Drofin which I want to put in a boat. I have a manual and from my front deck I can see part of Woy woy. Live at Killcare. I have a question for you. On the gear box. Is forward when the leaver is pointing towards the motor or is forward when the lever is pointing towards the back of the gearbox.
regards
Noel
detecta2
Username: detecta2
Posted on Tuesday, July 20, 2010 - 03:46 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hllo Noel, I'll have a look in yatch next wknd to be certain and let you know, when your ready if you want to look at wiring/setup etc,no probs,just let me know, shes down first canal on right coming down st huberts bridge,regards phill
noel_g
Username: noel_g
Posted on Wednesday, July 21, 2010 - 03:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Will send a private Email regarding the Name and Telephone number of a contact regarding your motor. I spoke to him about it and a few problems I have. He has parts and a great deal of knowledge re this motor.
Regards
Noel
Geoff Kirwood
Posted on Monday, June 27, 2011 - 05:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I've rebuilt mine - rings, injectors&pump element, bigend, valves, and am suspect of the governor. It revs well in neutral but won't build speed beyond idle under load - unless it gets a turbo boost from canned ether or hot air dryer into air cleaner. Then it still won't hold power, and I've gotten fresh diesel, drained filter etc. I'm worried the governor isn't increasing fuel flow but the manual has very little info. The local mechanic has very little idea. Geoff 0438 684318
bonair
Username: bonair
Posted on Thursday, March 15, 2012 - 12:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I've purchased a Drofin 12M which I am going to rebuild into a 12v generator set. Where can I get things like pump impeller, oil filter and other spare. Would appreciate any response.
Stefan
