Wonderment
Old Marine Engine » One and Two Cylinder Gas Inboards » Wonderment « Previous Next »
bruce
Username: bruce
Post Number: 294
Posted on Wednesday, February 15, 2012 - 08:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Anyone know who owns the Wonder marine engine with serial number 2592 in Ma. mentioned in the Wonder engine thread?
Post Number: 2754
Posted on Wednesday, February 15, 2012 - 01:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Wonder Thread
http://www.oldmarineengine.com/discus/messages/1/8226.html#POST11091
Post Number: 2755
Posted on Thursday, February 16, 2012 - 03:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce sent these Photos of two small WONDER mfg engines wanting to know if there was any additional info available since the postings in 2007 ?
Well not a lot but did come across these pages in a 1910 Wonder Catalog !
This 2 Hp eng also shows up in the 1906 catalog and that eng has the same mounting base design as Bruces engine here.
055
056
057
wcat2hp
This is the 4 hp but I believe Bruces eng is an earlier version because of the mounting base design ?
052
053
054
WCat3Hp
Ther are another dozen engine photos in this 1910 catalog if anyone is interested I will scan and post them ?
bruce
Username: bruce
Post Number: 295
Posted on Thursday, February 16, 2012 - 07:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks very much Richard, I would like to see the remaining 1910 catalog pictures
Post Number: 2756
Posted on Thursday, February 16, 2012 - 10:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
4
5
6
9
10
12
More to come !
Post Number: 2757
Posted on Thursday, February 16, 2012 - 11:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
15
18
204
20Tpl
24
30
40
Pc1
Pc2
pc3
boats
keith
Username: keith
Post Number: 348
Posted on Friday, February 17, 2012 - 08:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard,
Any idea of the year of this engine. Water exits thru the cylinder rather than the head. It is still a wet head. Not sure how you can purge the air in that the water can just circulate around the cylinder. Nothing to force it thru the head. 3 1/2" bore. Different manifold. Bemius timer. No tag but has the #3000 stamper on the cylinders and water pump.
Keith,
w
w
Post Number: 2758
Posted on Friday, February 17, 2012 - 11:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Keith
Researching many of these old engine mfgrs and their engs can be a real challenge and the Triple above is one of those !
I have had photos of this nice old original Wonder triple for several yrs but have never been able to put an exact year of mfgr on it ?
Many of The 1910 multi engines have the bolt on manifolds as opposed to the metal strap or clamps,and the external brass exit water piping.
This 1914 photo ad shows a triple with the similar intake manifold design but with the later strap-clamps.
W1914
I believe your eng above is probably late 1910-11 ??
I see the rear head is loose maybe take head off and photograph the block passages to find water flow ?
this is a Syracuse triple of very similar year, J.B. pionted out that the water flow was into the side of cylinders through manifold then circulating the cylinder and exited out of the head at the small almost square port on the bottom of the photo and then back into the manifold and exiting at the pipe fitting on rear top of manifold, I am Wondering if the Wonder eng may have same design ??
S
cylport
Good stuff Cool Old Engines !
keith
Username: keith
Post Number: 349
Posted on Sunday, February 19, 2012 - 09:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard,
I did check and the water can flow around the cylinder from the inlet to the exit. Nothing to force it up thru the head. The single cylinder #2547 shown above seems to be of similar design in that the water exits thru the cylinder rather than the head. It looks like a wet head also. Wonder? Wonder?
Keith
bruce
Username: bruce
Post Number: 296
Posted on Monday, February 20, 2012 - 06:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard, Any thoughts on how the 4Hp 2 cyl (Old base style Engine)with the aspirating carburetor might have taken in combustion air? Possible penetration/perforation into intake opposite the aspirating Carb???
Post Number: 2761
Posted on Tuesday, February 21, 2012 - 01:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce, The answer is I Don't Know!
W4hpbase
I looked at every photo in my files of these engs
none have an original Cornwell- Wonder made carb ? it would have to be different than the 3 hp engine --
3br
3hpcat
-- and a more conventional design, allowing flow through itself,possible that the 4 hp was an illustration and they depicted the wrong carb for the 4 Hp model ??
I don't have a perfect photo of the inside of the intake manifold but from what I can see there is no opening there and all photos show only a pipe nipple on the out side ?
4hpgrn
