Gray phantom ID and info
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray phantom ID and info « Previous Next »
Peter Waldon
Username: oilguy
Posted on Sunday, April 10, 2011 - 09:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
any info on the following would be sincerely appreciated GrayPhantom Model PH6 244
engine # 61363 on the head the casting numbers are 22356 and A600A 501 it has dual spark plugs and dual carbs
Jim Staib
Username: drrot
Post Number: 81
Posted on Monday, April 11, 2011 - 07:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
According to the charts at http://www.finewoodboats.com/Gray.htm
60000 numbers are 1936.
Peter Waldon
Username: oilguy
Posted on Monday, April 11, 2011 - 10:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Jim
do you know any more about this model HP @ RPM etc? The only info I've been able to find on the net is for 39 and newer engines. Is there an info source for engines that are pre 39 Thanks
Jim Staib
Username: drrot
Post Number: 82
Posted on Monday, April 11, 2011 - 10:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Peter,
Just a guess but sounds like the 125hp with dual ignition option. Usually a brass plate with horsepower rating on the reverse gear cover. Got any photos you can post? sounds interesting.
Peter Waldon
Username: oilguy
Posted on Sunday, February 05, 2012 - 04:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
36 gray phantom 1936 gray phantomgray phantom engine plate
