Ford V8-60 Transmission ? |
Brad Hunter
Member Username: silverghost
Post Number: 27 Registered: 05-2009
| Posted on Friday, January 20, 2012 - 12:53 pm: |
What make & model number marine transmission & reverse gear would bolt-up to a 1930s Ford V-8 60 marine conversion engine ? Would there be any engine bellhousing , or flywheel to transmission shaft adapters , or damper plate coupler needed ? My engine now has the flywheel & the old auto style clutch friction plate & pressure plate still bolted to the flywheel. Does anyone have an old marine transmission/reverse gear that will fit my Ford V8-60 engine without making any custom adapters ? 1-1 ratio prefered Thank's Brad Hunter 1 215 947 4676 [email protected] |
Gonzo Couto-Lain
Member Username: gonzo
Post Number: 28 Registered: 06-2011
| Posted on Saturday, January 21, 2012 - 06:57 pm: |
It is a 59A pattern. http://www.wilcap.com/flathead.html#FHID |
