Gray Marine Phantom 6 - 112 with twi...
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Marine Phantom 6 - 112 with twin zenith carbs « Previous Next »
John M
Username: jhkm12345
Posted on Tuesday, April 25, 2017 - 11:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is for either the motor and trans and/or all the components to build your own runabout wood boat.
112 hp gray marine engine has 2 updraft zenith carburetors. Flat head inline 6 very cool motor. motor spins and has oil pressure. I made it fire on starter fluid after soaking the cylinders for a few days and building oil pressure. will run.
Motor was installed in a 1963 Correct Craft american skier and I had intended to use the steering, rudder, cutlass bearing, driveshaft, stuffing box, propeller, fuel tank, etc in a home built boat but just purchased another project boat to restore instead of building from scratch.
All components are included
All the deck hardware (chrome is poor and will need to be rechromed), lights, cleats, etc are included.
anyone looking to build an inboard runabout similar to a chris craft, gar wood, hacker, riva, etc will need all these components.
$1500 for the lot or make me an offer. also, will include the correct craft hull and deck if you want it.
MARK D WALICK
Username: lesnlearned
Posted on Tuesday, October 24, 2017 - 11:41 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi John. Is this engine and tranny still for sale? What year were they manufactured? Do you have the serial number? I'm looking at a boat that had this engine (and is missing it), but it needs to be correct.
Thanks!
Mark
