rick zimm
New member Username: rickz713
Post Number: 1 Registered: 04-2008
| Posted on Tuesday, April 29, 2008 - 08:46 pm: |
i have a pair of 130 hp engines in a 1938, 38' chris craft D.C.E.B. I need to replace the fuel pump diaphragms. Can anyone tell me what kind of Hercules engines i have? The serial # on one is MR011335. |
Lawrence T Wolfe
Post Number: 286 Registered: 07-2003
| Posted on Wednesday, April 30, 2008 - 07:21 am: |
Those numbers don't show in my books. |
Lawrence T Wolfe
Post Number: 287 Registered: 07-2003
| Posted on Wednesday, April 30, 2008 - 07:43 am: |
If anyone would have something i would think it would be Zimmermans in PA. they are old cletrac dealers. Cletrac's used herk engines mostly. Many of the old herks used the same fuel pump. Beautifull boat by the way. Most of the old herks had numbers cast just above the oil pan on the right side. Look for them and post here. Allso the pump may have stamped numbers on it. Zimmermans 717 738 2573 or WWW.olivercletrac.com |
Scott Noseworthy
Member Username: scott_n
Post Number: 22 Registered: 02-2008
| Posted on Wednesday, April 30, 2008 - 04:45 pm: |
The hercules no. is just under the head in the middle on the intake side on a small machined spot about 2" long if the cris craft no. is KLC you have a QX block. Classic boat connection has rebuild kits for your pump 507-344-8024 |
rick zimm
Post Number: 2 Registered: 04-2008
| Posted on Monday, May 12, 2008 - 08:57 am: |
 thanks for the input guys. i will try and get the numbers this week. i do have a few pics of the pump if that will help! |
boabWhodaynof
New member Username: boabwhodaynof
Post Number: 1 Registered: 11-2011
| Posted on Thursday, December 08, 2011 - 10:29 am: |
<a href=http://www.uggbootsgreecesales.net>ugg μποτες</a>  ενός ατόμου διαφημίσεις Ï€Ïαγματικά από το Îτσι μποÏεί Ï€Î¿Î»Ï ÎºÎ±Î»Î¬ να είναι εμφανίζονται με βάση το τι θα μποÏοÏσε να είναι το Ï€Î¿Î»Ï Ï‡Ïήστη θα μποÏοÏσε να για την απόκτηση μÎσω του διαδικτÏου . Î Î¿Î»Ï ÎµÎ¯Î½Î±Î¹ στην Ï€Ïαγματικότητα , το Ï€Ïαγματικό λογισμικό ταιÏιάζει με την Ï€Ïακτική μια διαφήμιση ως Ï€Ïος να σας βοηθήσει να κάποιου είδους το συγκεκÏιμÎνο Ï€Ïόσωπο είναι τώÏα οφείλεται σε . ,<a href=http://www.uggbootsgreeceshop.com>ugg</a> ΜÎχÏι στιγμής, το κόστος πηγαίνει, η πολλαπλÎÏ‚ ιστοσελίδες Ï€ÏÎπει δεν θεωÏοÏνται δεν Ï€ÏÎπει να οÏίσετε πίσω στο χÏόνο Ï€Î¿Î»Ï Ï€ÎµÏισσότεÏο από ÏŒ, τι μποÏεί καλό πάνω πεÏίπτωση να τα αγοÏάσει κοινÎÏ‚ διακομιστÎÏ‚. Είστε σε θÎση να Ï€Ïαγματικά αγοÏάσουν πεÏιοχÎÏ‚ σχετικά με η φιλοξενώντας επιχείÏηση που χÏησιμοποιεί καθιεÏωμÎνη ÏοÏχα στο δÏόμο για την σε όλους σας ιστοσελίδα . http://www.uggbootsgreeceshop.com Τι βολικό είναι χωÏίς αμφιβολία που σας να ξεκινήσετε με ότι και αυτοί οι Ï„Ïποι την επίτευξη από εσάς. Just for εκείνους που δεν Îχουν Ï€Ïόσβαση σε ότι θα κάθε , το συγκεκÏιμÎνο ηχεία του υπολογιστή συν μποÏεί εναλλακτικά να χÏησιμοποιηθεί για που λαμβάνονται για την ζουν σε όμοÏφα λάβουν μÎÏος. |
AntetsGat
New member Username: antetsgat
Post Number: 1 Registered: 12-2011
| Posted on Sunday, January 08, 2012 - 09:28 am: |
<a href=http://www.beatsbydresouthafrica.eu>beats by dr dre</a> http://www.beatsbydrdreswitzerland.eu |
