david brown
Member Username: woodman
Post Number: 4 Registered: 10-2005
| Posted on Saturday, October 07, 2006 - 08:05 am: |
Can anyone tell me the following info. re; GRAYMARINE 136 please. (1) max rpm, (2) cruise rpm, (3) torque and weight in lbs. (inc. gearbox,direct drive + astern) |
Douglas J. Beattie
Member Username: gannet
Post Number: 9 Registered: 04-2005
| Posted on Saturday, October 07, 2006 - 07:41 pm: |
David this engine is rated at 136hp. at 3600 rpm. It weighs 825 lbs. and they don't mention torque, but you can figure that out. Cruise rpm is another thing that is vessel specific. |
JOHN DEBATES
Member Username: cam_gear
Post Number: 4 Registered: 09-2006
| Posted on Monday, October 09, 2006 - 09:40 am: |
DAVID IS THE ENGINE A V8A-136? IF SO IT IS 215 CU.IN. ALUMINUM 9:1 COMPRESSION RATIO POWER RATING 136 HP @4500 RPM INTERMITTENT RATING 105 HP 4300 RPM DRY WEIGHT 470 LBS WET WEIGHT 501 LBS BORE 3.500" STROKE 2.800" CARBURETOR ROCHESTER 2-BARREL, SPEC. 7020992 FRESH WATER TEMPERATURE 190 F. JOHN |
Hakan Pettersson
Member Username: hugger69
Post Number: 29 Registered: 10-2010
| Posted on Thursday, September 01, 2011 - 07:50 am: |
Does anyone have any pics of this 215 cui V8 from Gray?? I miss the carb to this engine from Rochester 2 Jet 7020992! |
