Sabb Air Filter
Old Marine Engine » Diesel Inboards » Sabb Air Filter « Previous Next »
earlybird
Username: earlybird
Posted on Wednesday, November 21, 2007 - 07:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My Sabb 2HG has no air filter and I have the feeling that the previous one was re-usable. Does anyone know where I can find one of these or a suitable replacement?
jimdereynier
Username: jimdereynier
Posted on Wednesday, November 21, 2007 - 10:47 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Air Filter for Sabb 2HG.
I asked the same question to Bill Miller,Sabb America. He said the filter does not exist and I should not baby the engine. I did look at some possible filters but worried about changing the amount of vacuum. The air cleaner housing is still a valuable tool. In one this year's " Good Old Boat" magazine was an article about how to shut down a run-away diesel engine- plug the air inlet hole.
regards, [email protected]
Erik Bellamy
Posted on Tuesday, November 05, 2013 - 07:26 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My friend has a narrow boat with a Sabb 2H 18hp two cylinder diesel engine.
There is no air filter in the muffler housing.
Should there be one ?
If so what should be fitted ?
A manufacturer and part number would be really helpful.
Regards Erik
[email protected]
jimdereynier
Post Number: 90
Posted on Wednesday, November 06, 2013 - 08:37 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There is no filter element. But you should take the time to get the filter cover. If you ever have a run away engine, you can plug the filter with a 3/4" rubber plug.
Take the measurements for the lip on the intake manifold where the filter cover latches on. Last week I saw a Volvo 2 or 3 cylinder engine with what looked like the same air filter can.
