GRAY MARINE V8C-188 | CARB QUESTION
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » GRAY MARINE V8C-188 | CARB QUESTION « Previous Next »
Bartlomiej Wnek
Username: bartlomiej
Posted on Tuesday, August 02, 2011 - 02:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello folks!
My question is this: Does anyone know why there would be "poofs" of smoke coming out of my carb?
There is old fuel still in the tank and this fuel takes a lead additive. The fuel has sat over the winter so is that possibly why the smoke is occurring?
I had ran the motor recently to get the water through the cooling system. The motor runs amazingly well. The other day I started it up and as mentioned it ran well, then I turned it off turned it back on maybe 10 minutes later and it would act like a backfire but just white smoke came out... Just a big "poof" of smoke... I've never seen this before. Can anyone please tell me what I should do... I know the first will be to put fresh gas in, but after that where do I go?
Any help would be greatly appreciated!
BW
