Removing generator from Model 620
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Removing generator from Model 620 « Previous Next »
kim hartshorn
Username: kimhartshorn
Post Number: 14
Posted on Thursday, May 05, 2011 - 09:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What am I missing about removing the generator from a model 620? It has the shaft drive water pump and it is removing the shaft that I am not figuring out, unless it is possible that the generator removes from the front? Do I have to physically remove the water pump also?
Also, are there replacements available for the rubber links in the drive shaft?
dan m
Posted on Thursday, July 21, 2011 - 11:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi kim, the other viking guy,you need to back off the water pump to make room for the gen to move out. my pump is sitting on a bracket and can be removed quite easily.hope that helps.
