Mike Schryer Visitor
| Posted on Wednesday, July 06, 2011 - 10:17 pm: |
I had fuel pump and carb rebuilt. motor ran after about 15 mins of cranking.now motor only runs when spraying ether.electrical seems fine.any suggestions. |
Gonzo Couto-Lain
Member Username: gonzo
Post Number: 14 Registered: 06-2011
| Posted on Wednesday, July 06, 2011 - 10:52 pm: |
That looks like a fuel problem. You need to test the fuel pressure and delivery volume. If that is OK, then make sure the needle valve in the carburetor is not stuck |
