Neptune 1.7 hp water pump impeller
Old Marine Engine » Gears, Transmissions, and Propellers » Neptune 1.7 hp water pump impeller « Previous Next »
Christian Schmelzle
Username: chrisgeorge
Posted on Tuesday, May 17, 2011 - 11:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I purchased a new Neptune Mighty Mite 1.7 hp around 1970. I haven't run it for many years but I tried it out and it started right up. My concern is the water pump impeller. If it is rubber it should be replaced. Where can I purchase this item?
Post Number: 1340
Posted on Wednesday, May 18, 2011 - 08:18 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You will most likely find what you need at
www.aomci.org
Hope this helps
