55 graymarine 100 6cyl.
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » 55 graymarine 100 6cyl. « Previous Next »
Mike Schryer
Posted on Wednesday, July 06, 2011 - 10:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I had fuel pump and carb rebuilt. motor ran after about 15 mins of cranking.now motor only runs when spraying ether.electrical seems fine.any suggestions.
Gonzo Couto-Lain
Username: gonzo
Post Number: 14
Posted on Wednesday, July 06, 2011 - 10:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
That looks like a fuel problem. You need to test the fuel pressure and delivery volume. If that is OK, then make sure the needle valve in the carburetor is not stuck
