What type of motor is this?
Old Marine Engine » Blaxland » What type of motor is this? « Previous Next »
TrevorFiegert
Posted on Tuesday, March 15, 2011 - 12:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ihad this motor given to me a number of years ago . Does anyone recognise the Type? It is not a BlaxlandType????
kyle bennett
Username: kylebt
Posted on Wednesday, March 16, 2011 - 09:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Trevor
That motor look like a Vinco
Eric Schulz
Username: eric_schulz
Post Number: 65
Posted on Wednesday, March 16, 2011 - 10:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The whole bottom end of that engine looks to be Penguin. I have never heard of a Penguin without a detachable water jacket on the cylinder barrel. Could the cylinder be off a Blaxland, as they were flange mounted?
Not a Vinco. They didn't use a flange-mounted cylinder.
Eric
David Myers
Username: dave_myers
Post Number: 99
Posted on Wednesday, March 16, 2011 - 10:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Not a Vinco as Eric confirmed.(G'Day Eric)
Looks to be a Simplex 3 HP 2 stroke.
Not a lot around these days.
Dave
Laurie Derwent
Username: laurie_d
Post Number: 93
Posted on Wednesday, March 16, 2011 - 10:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Trevor,
It looks very much like a Blaxland 'Super pup' to me. I understand they were rated as 4 1/2 hp and the twins were rated as 10 hp. A pic from the other side could help. Sorry it's been a long time since a saw a 3hp Simplex and will make inquiries with a brother whose memory is better than mine. Regards Laurie
TrevorFiegert
Posted on Wednesday, March 16, 2011 - 11:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Eric, I think you are probably right. I reckon itis a Penguin with a Blaxland pot fitted. The crankcases have extra bronze sealing around the crankshaft bearings and the bottom crankcase has an extension section for the Magneto mount.Drive to the prop would have been via the Flywheel
Laurie Derwent
Username: laurie_d
Post Number: 94
Posted on Thursday, March 17, 2011 - 05:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Having conferred with trusty brother and Neil Jones it seems the magneto drive is consistent with a Simplex (and not Blaxland) but the water pump appears different than the Simplex. So who has some good pics of a Penguin? Cheers.
Brian Marriott
Username: pdp8user
Posted on Thursday, March 17, 2011 - 06:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There are some good pics on this board. Try:
http://www.oldmarineengine.com/discus/messages/1/138570.html
or
http://www.oldmarineengine.com/history/Penguin/penguin_marine_engine.htm
Cheers, Brian
Trevor Fiegert
Username: trevorfiegert
Posted on Thursday, March 17, 2011 - 09:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Brian , They were excellent photos on the website you suggested. It is certainly a Penguin motor.If I remember rightly the removable water jacket and cylinder were "shot" rusted out and an attempt was made to fit a Blaxland Pot to it. These motors are probably pretty rare to find nowadays.
Regards Trevor.
Tim Craig
Username: mangrove
Post Number: 9
Posted on Monday, May 09, 2011 - 07:01 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Definitely a penguin, they had a basic dog clutch inside the flywheel where you can see the small shaft and retaining holes. Also as discussed the
magneto is correct and in that position.
Tim
