Plamer 60
Old Marine Engine » Palmer Engine Co » Plamer 60 « Previous Next »
Tom Kelly
Username: tom_k
Posted on Monday, March 30, 2009 - 12:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 30ft cornado with a palmer 60 runs well.I switched to a Indigo three blade prop it dose cause the engine to run at a little higher rpm but its almost like its pulling a load.Any ideas?
Post Number: 728
Posted on Monday, March 30, 2009 - 05:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Is you forward gear slipping when you rev up the engine?
Tom Kelly
Username: tom_k
Posted on Monday, March 30, 2009 - 06:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
No,it dose rev up when you take it out of gear mabe 300 rpms or so.
Post Number: 729
Posted on Tuesday, March 31, 2009 - 08:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
That sounds normal. I was thinking more along the lines the prop is overloading the engine and the clutch is slipping.
Tom Kelly
Username: tom_k
Posted on Tuesday, March 31, 2009 - 06:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There is no slipping.It just seems like a load but I havent realy run the rpms much above 1500-1600.
