Another unknown on eBay
Old Marine Engine » Unknown Engines - post here with photos » Another unknown on eBay « Previous Next »
rbprice
Posted on Saturday, November 08, 2003 - 11:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Anyone recognize this little engine?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=11754&item=2569122389
Bob Price
Jim McCracken
Posted on Tuesday, November 11, 2003 - 12:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm still trying to identify a single cyl. 4 stroke marine engine I own.I would include a picture but presently the cyl. is removed for water jacket cleaning and repair.
It has a 5" bore,Schebler carb,Cuno timer,1/2"
spark plug in the side of the cyl below the head.
The flywheel is solid 19"X 3 1/2,it has 4 round 3"? holes in the inner part.
Now the unique part:The crankshaft between the flywheel and main bearing has a spline cut in it.
Mounted above that are three 4"? gears meshed in a line.The middle one is driven from the crank spline and in turn drives the other two gears that are attached to single lobe camshafts on opposite sides of the engines.
The water pump is driven by an eccentric on the exhaust cam.The exhaust rocker has a brass handled compression release that moves the rocker pivot eccentric.
This engine was one of 3 three I bought 25 years ago.The others were Canadian so possibly this is also? any thoughts or ideas are welcome.
Jim McCracken
Crawfordsville,Or.
[email protected]
