Johnson-Strob(sp), circa 1929
Old Marine Engine » Diesel Inboards » Johnson-Strob(sp), circa 1929 « Previous Next »
Thomas Brown
Posted on Sunday, November 09, 2003 - 03:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Trying to restors a 1929,80' vessel that has a Johnson-Strob(or Storp?) 4 cyl. (12" dia, 12" stroke) direct drive, air start diesel. The engine had two phase fuel injectors (low pressure for starting and high to run) but they are missing. The engine is basicly clean and sound with new bearings, seals, etc. but but I have no idea where to find the injectors or any other parts if needed. Any ideas or thoughts would sure help. Thanks, Tom
raymond
Posted on Monday, June 28, 2004 - 07:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi there Thomas Brown.
By direct drive, air start I presume you mean direct reversing. The 12x12 cylinders doe's not sound right for that era. A number of questions first, where was the engine / ship built, if you are not sure of the make of engine how do you know that those " new parts are in it? how about the two " phase " injectors? and can you give more details?? I really would like to help but need more info. regards ray.
Ken Sharp
Posted on Wednesday, August 17, 2005 - 11:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1971 Johnson 100 Hp 4 cylinder (outboard) and am having problems getting the ignition to operate. I have replaced the amplifier, coil, ignition switch, clipper and point set. I have a manual on this motor and have done the prescribed test sequences, to no avail. The wiring at the motor is also correct per the manual. Do you have any ideas?
Moderator
Username: andrew
Post Number: 1189
Posted on Friday, August 19, 2005 - 02:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
ken,
you should try posting that question on the board at marineengine.com in the johnson/evinrude category.
This board is for older inboards, not outboards...
poker casino572
Posted on Monday, March 06, 2006 - 02:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 716
poker casino372
poker casino poker 204
