We need help identifying this, PLEASE!!
Old Marine Engine » Unknown Engines - post here with photos » We need help identifying this, PLEASE!! « Previous Next »
Laurie Houdashelt
Posted on Sunday, April 06, 2003 - 09:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We have what we believe to be an "atlas" boat motor. Looks like it might be 1930's or 1940's. Acquired at a sale, it fired right up! There are no identifying marks on it other than a serial #. It is #0042436. Any info you could give us would be much appreciated. Thank you very much, Laurie
Posted on Sunday, April 06, 2003 - 01:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Laurie,
Maybe you could describe it a little further..
Is it an inboard engine or an outboard motor?
How many cylinders?
If it is an outboard, it is probably is probably a Gale made motor distributed by The Atlas Supply Company of Newark. There is brief description of it in Peter Hunn's book The Old Outboard Book.
Regards,
Andrew
Dan Evenson
Posted on Thursday, April 17, 2003 - 01:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We would appreciate any information on a Frazer Adams 4 hp single cylinder. Serial # 141. Made by Frazer Bros. Company Adams, N.Y. Thank you. Dan
Posted on Thursday, April 17, 2003 - 06:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Frazer Adams engines are in 1914 engine makers index listing. They listed 1-2-3 and 4 cylinder, two stroke marine engs.
Intersting that two different 4 Hp singles were available.
1. under medium duty engs a 3 7/8 bore by 4" stroke, 800rpm weight 175lbs.
2.under light weight high speed engs a 3 3/4 bore
by 3 3/4 stroke, 900rpm weight 150lbs.
No advertising or articles on first look, if something comes up I'll post it!
