Volvo MD1
Old Marine Engine » Diesel Inboards » Volvo MD1 « Previous Next »
moisez
Username: moisez
Posted on Tuesday, April 18, 2006 - 09:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi, I have just gotten a boat with an MD1 in it. It has been sitting for a few years. Can anyone give me some advice on the things that absolutely need to be checked before I hit the starter button to see what happens? I have one manual for it, but it is more to the tune of how to fix things, not how to make sure it is ok to turn it over. Thanks, Jack Harrill
amy_ann
Username: amy_ann
Post Number: 10
Posted on Wednesday, April 26, 2006 - 05:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jack,
Got plenty of MD1's in operation after prolonged periods of unuse. Some good & some bad! Best thing is to drop me an email and leave us know what things look like- face value at present or any past history the engine may have. Could pass on some time saving tips & frustration free efforts there.
Regards - Pat.
PETER WHITE
Posted on Wednesday, November 01, 2006 - 12:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
COULD ANY ONE TELL ME WHERE THE DIPSTICK IS ON AN MD1 THANKS PETER
lizardlace
Username: lizardlace
Posted on Thursday, March 15, 2007 - 08:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi does anyone know the torque settings for an MD1?
kayjaydee
Username: kayjaydee
Posted on Saturday, August 18, 2007 - 02:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Searching for a replacement gearbox for VOLVO PENTA MD1.Would appreciate any leads.Alternatively would consider complete engine.
tom hastie
Posted on Monday, October 01, 2007 - 07:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a complete engine. Compression seems good the fuel pump is not pumping Bosh type. Starter etc appear fine. It has a crack in the exhaust elbow
southportsailor
Username: southportsailor
Posted on Saturday, June 14, 2008 - 08:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We have a Volvo Penta 2001 (MD1?) that hasn't been started for about a year. Does anyone have any good tips for cold-starting this engine?
adsum
Username: adsum
Posted on Monday, June 16, 2008 - 03:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Torque settings MD1
Tightening torque for the four big cilinderhead nuts is 108 Nm (11 kgm / 80 lb.ft.) and for the two small nuts is 44 Nm (4.5 kgm /33 lb.ft ). The tightening sequence is important. Start with a big nut in the middle then the one diagonally opposite the first one at the corner, next the other big nut in the middle and further the last big nut at the corner, then the small nut diagonally opposite the last big nut and at last the other small nut.
To start a cold engine after a long period of rest you should check the fuel system (valves, filters, venting), clean air filters, check the oil lubricating level, check the waterinlet and drainplugs, check V-belt tension and batterypower. Move the speed control to half throttle and press the cold starting device. Then start the engine with the startermotor or dynastart. For hand starting (a heavy job), first crank the engine a few revolutions with the decompression lever in vertical position before pressing the lever down to start the engine.
ndbrown
Username: ndbrown
Posted on Friday, October 17, 2008 - 10:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am looking for anyone with wiring diagrams or photos of a wired Volvo Md1 with a dynostart dynamo. I bought a 1966 Cheoy Lee Cadet with a motor that appears to be in great shape service records from the early 90's sadly some one stripped all the electrical from the entire boat as some sort of refit fantasy. Now I am stuck as to what to do with the dynamo.
adsum
Username: adsum
Posted on Sunday, October 19, 2008 - 05:49 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Find a manual with diagrams at:
http://www.volvo.com/volvopenta/global/en-gb/marine_leisure_engines/engines/out_ of_production_engines/
I know there is a diagram of MD1B and I guess it's allmost the same wiring diagram as for the MD1
adsum
Username: adsum
Post Number: 7
Posted on Sunday, October 19, 2008 - 05:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think this link works better:
http://www.volvo.com/volvopenta/global/en-gb/marine_leisure_engines/engines/out_ of_production_engines/out_of_production_engines.htm
thecaptainsfolly
Posted on Wednesday, December 10, 2008 - 11:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi I need to get hold of a good injector pump for my MD1 1960 or will have to buy new engine :-( and miss the putpuptput
any ideas or what engine can replace it
