E.M White 20ft Inboard Power Canoe......
Old Marine Engine » Boats with Early Inboards » E.M White 20ft Inboard Power Canoe.....Engine Help « Previous Next »
hillierkim
Username: hillierkim
Posted on Saturday, August 23, 2008 - 02:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello this is my first posting at this site. I have a E.M. White power canoe that I am restoring. This plan is to make it as historicly correct as possible. The problem I am having is that I can't determine what brand, type and size motor would have been installed. It was made in Maine somewhere in the 1905-1918 range. I would be great to hear from anyone with info or ideas about this project. Thanks in advance, KimE. M. White
Post Number: 1778
Posted on Saturday, August 23, 2008 - 02:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
E.M.White & Company 1906
w06
Post Number: 1779
Posted on Saturday, August 23, 2008 - 06:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
T.M.Chapman & Sons Was an Iron Foundry and Machine shop in Oldtown, Maine est. around 1900.
They made many things over the years, were big in Heading & Hoeboard Machines. The marine engines were canoe sized 2 cycle -single and twins - they had a 6 Spoke flywheel with T.M.Chapman cast into the face.
Don't know if any are still in existence ??
hillierkim
Posted on Saturday, August 23, 2008 - 08:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank You Richard,
I now have a new path to follow. Your help is greatly appreciated. Kim
microhydro
Username: microhydro
Posted on Friday, July 10, 2009 - 08:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Kim - How is your restoration coming - Our em white has a Dubrie 4 stroke - later model as pictured in the 1923 catalog on this site. The canoe ad cds available on whca site show several engine options for different periods- get in touch if you need pictures on installation - we are doing wel on restore - just waiting for canvas sealer to dry so we can paint - Best RonEm White under restorationFinising up
searcher
Username: searcher
Post Number: 315
Posted on Friday, July 10, 2009 - 10:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
To date, I have seen 6 Chapman engines, all two cylinder, jump spark. There is some variation in the ignition systems, one of the most interesting is the wipe spark.
This one is more typical of the type.
