Volvo md2
Old Marine Engine » Diesel Inboards » Volvo md2 « Previous Next »
gaurdian101
Username: gaurdian101
Post Number: 8
Posted on Tuesday, January 18, 2011 - 12:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just got this engine and need to know the rpms of it min and max please
oslin04
Username: oslin04
Post Number: 52
Posted on Tuesday, January 18, 2011 - 06:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You can down load the manual from the net FREE
gaurdian101
Post Number: 10
Posted on Tuesday, January 18, 2011 - 09:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thanks I found a download now for another help on my md2 when I put in gear on reverse you move the lever away from the engine or do you move it forward I have know Idea thanks for everones help vince
oslin04
Username: oslin04
Post Number: 55
Posted on Wednesday, January 19, 2011 - 05:49 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Move the lever aft away from the engine for reverse vince, buy the way cold starting, open the throttle fully out of gear and depress the brass cold start button on the injection pump (you may have a cable attachment for this or not) turn the key to start and as sone as it fires up reduce the throttle to about a quarter and allow the engine to warm up a bit before reducing to tick over, the cold start will come off when you reduce the throttle.
hope this helps
Keith
gaurdian101
Post Number: 11
Posted on Wednesday, January 19, 2011 - 09:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thanks for your info about putting into gear but a little confused about the rest I see the brass cold start button thanks..... I didn't know what that was till now?....but what is the tick over? and the cold start will come off when the throttle is reduced? I'm new to this engine and wanting to put it into my boat so all the info is much appreciated I can't find anyone in my small town that knows anything about this engine so all the info is much appreciated teith............ vince
oslin04
Username: oslin04
Post Number: 56
Posted on Thursday, January 20, 2011 - 07:37 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Vince, the tick over is the speed the engine runs at with no throttle the same as your car with your foot off the throttle when it is standing in the drive (the engine is ticking over), the cold start brass button is depressed when you cold start it, and the throttle is set to max for the start, when you reduce the throttle after the engine has fired up the brass button will automatically pop up again ready for the next cold start.
Keith Marine Engineer.
RogerW
Posted on Saturday, April 16, 2011 - 05:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi all
I've just replaced the md2b on my boat with one i bought secondhand. It starts and runs perfectly and i have fitted and wired an alternator which is also working fine. However i have been starting it by hand cranking which is not easy and now want to fit a bosch dynastart just to do the starting bit....Does anyone know if it is ok to do this and is it just a matter of earthing the dynastart and running a battery 12v to it via a solenoid to wind it over. Also will it matter that i am not using the dynastart for charging purposes? All help on this will be greatly appreciated, thanks Roger.
matt_morehouse
Username: matt_morehouse
Post Number: 86
Posted on Monday, April 18, 2011 - 09:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
"Tick over" equals "idle" in American English.
