Richard Alcock
Advanced Member Username: raa
Post Number: 47 Registered: 02-2007
| Posted on Thursday, March 01, 2012 - 02:50 pm: |
I have a Kingston 5 ball which is missing the inlet air horn or ring. I understand that Kingston supplied them with a cast horn which could be fitted with a choke and also a ring which had a series of holes in a ring. If someone has a 5 ball with the ring I would sure appreciate the ring diameter , height and the hole size, number of holes. Cheers and thanks Dick\pop,p2280003.jpg}\popjpegp2280002.jpg} |
Phillip Allen Chart
New member Username: billy_bolly
Post Number: 1 Registered: 08-2011
| Posted on Thursday, March 01, 2012 - 04:11 pm: |
My Stuart Turner R3M gearbox appears to be faulty in that the engine stalls when put into either forward or reverse gear. Turning the engine over by hand in gear, forward or reverse, does not turn the propellor shaft. The propellor shaft is free to turn when not connected to the gearbox. The gearbox coupling moves slightly forward or back when the gear selector is moved to ahead or astern. The coupling is not touching the floorboards. Any suggestions are great fully received, thenk you. |
