Bob Brown Visitor
| Posted on Tuesday, February 15, 2011 - 08:08 pm: |
Hi all I would like to know what is the best oil to use when mixing it in to the petrol for my blaxland capman engine. and also where can i get my magneto service thnaks Bob |
Bruce Findlay
Senior Member Username: bruce_findlay
Post Number: 52 Registered: 03-2006
| Posted on Tuesday, February 15, 2011 - 08:27 pm: |
Hi Bob. Oils, petrol and grease have been discussed on this forum in great detail about a year or so ago. Check back through the posts and you will find it. Todd Vidgen is the bes bloke to fix your maggy. Cheers, Bruce |
Greg Y
Senior Member Username: gregoryan
Post Number: 78 Registered: 09-2004
| Posted on Tuesday, February 15, 2011 - 09:19 pm: |
i had to ring many oil chemists over the years before i found where to get the [Blaxland-recommended] monograde SAE50 in domestic quantities. Apparently its a 'base oil' [which hasn't had the toxic chemical-packages or detergent added to it which stink like a worn-out car when burnt] Tru-Blu Oils in VIC AU. 2yr ago it was $20 for 5 litre + $15 postage.! there you go! |
Bruce Findlay
Post Number: 53 Registered: 03-2006
| Posted on Tuesday, February 15, 2011 - 10:18 pm: |
Hi Greg, yeah I did a lot of research on the same subject but found it pretty hard to find a straight 50 grade oil in quantities less than 20 litres, even Tru-blu. I ended up using Penrite Vintage EP Mild Gear Oil which is available in 2 litre packs. It has been working fine for me for about 12 months (sorry Todd, I know you'll disagree). Cheers, Bruce F. |
Andrew Munns
Member Username: johnoxley
Post Number: 17 Registered: 04-2010
| Posted on Tuesday, February 15, 2011 - 10:35 pm: |
I'd be concerned about EP additives in a crankcase with hot salty air and bronze components. I know you musn't use EP oils in older worm differentials that have bronze components. There are heavy gear oils around that do not have EP additives (nasty Sulphur and Chlorine). |
Bruce Findlay
Post Number: 54 Registered: 03-2006
| Posted on Tuesday, February 15, 2011 - 11:25 pm: |
Hi Greg, yeah I took that into consideration. Penrite claim the the Mild EP is compatible with copper alloy components because it was designed for vintage engine gear boxes. Bruce. |
