Snowmobile coming down the Mississipp...
Old Marine Engine » One and Two Cylinder Gas Inboards » Snowmobile coming down the Mississippi River to Hastings. « Previous Next »
Post Number: 393
Posted on Saturday, January 08, 2011 - 12:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Snowmobile coming down the Mississippi River to Hastings. ca. 1910. I wonder what they used for anti-freeze?
Moderator
Username: andrew
Post Number: 1110
Posted on Saturday, January 08, 2011 - 12:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Wow, great looking rig.
I need one of those here in Vermont!
john_archibald
Username: john_archibald
Post Number: 167
Posted on Saturday, January 08, 2011 - 12:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
How did it propel itself?
richardday
Post Number: 935
Posted on Saturday, January 08, 2011 - 01:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Alcohol
johnny
Username: johnny
Post Number: 377
Posted on Saturday, January 08, 2011 - 07:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is a Detroit Engine Works on a snow mobile. However It's a stationary Detroit not a marine.
johnny
Username: johnny
Post Number: 378
Posted on Saturday, January 08, 2011 - 08:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Another fine example of transportation back in the day. I'm guessing the gentleman probably had a hot dog or biscuit dangling from the end of that pole he is holding. Oops, getting off subject here a little bit. Sorry.
gregoryan
Username: gregoryan
Post Number: 73
Posted on Saturday, January 08, 2011 - 08:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
How about water-cooling!? Keel cooler?; run the water through the skis!?
Post Number: 394
Posted on Saturday, January 08, 2011 - 10:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are a couple more from the same set, although they are not marine engines.
and a couple of newer European machines just for fun.
solarrog
Username: solarrog
Post Number: 468
Posted on Saturday, January 08, 2011 - 11:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
motorwheel ice runner
another one
Post Number: 395
Posted on Saturday, January 08, 2011 - 11:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I still don't know how the first one gets the power to the ice. It looks like a gas tank on the near side, and a cooling water tank on the far side, and possibly a mag off the flywheel, and a whistle behind the cylinder.
johnny
Username: johnny
Post Number: 380
Posted on Sunday, January 09, 2011 - 07:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I bet you freeze to death with those prop-mobiles especially the puller one.
Bill, On the first photo maybe there using some kind of cork screw.
Post Number: 408
Posted on Sunday, January 23, 2011 - 09:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
3 hp boat motor on this one. 1909
solarrog
Username: solarrog
Post Number: 469
Posted on Sunday, January 23, 2011 - 12:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can I sit up front please? I will need my elboe in the future I'm sure. one little momment of inattention and the guy in back will be called righty.
johnny
Username: johnny
Post Number: 381
Posted on Sunday, January 23, 2011 - 12:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
He gets that paints leg or jacket hung up in there and he'll be talking with a real high pitch voice.
