Mystery Object!
Old Marine Engine » Carburetors, Mixers, Vaporizors » Mystery Object! « Previous Next »
Phil Gemeinhardt
Username: philg
Post Number: 39
Posted on Monday, January 10, 2011 - 08:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi All, when I first got this object I thought it was a mixing valve and then I thought maybe it was a check valve but there is no provision for a gas line and needle valve - but there is a butterfly, can anyone tell me what this is please?
Phil
miro forest
Post Number: 543
Posted on Monday, January 10, 2011 - 09:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This looks like a check valve that is installed between a carb and the motor. The carb has the fuel , bowl etc etc ,
Your item is interesting because of the throttle valve upstream of the check valve.
The Gray check valve is similar but without the throttle valve part.
William Schaller
Post Number: 398
Posted on Monday, January 10, 2011 - 10:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
here you go.
http://www.antiquengines.com/Identifying_Engines_&_Parts.htm
DMCSC engine non-return air intake valve used in conjunction with DEW fuel injector
