dmurzic Visitor
| Posted on Monday, October 18, 2010 - 11:51 am: |
I'm concidering an oil filtration system on a f-162 block.there are many opinons on this subject.does anyone here have an oringinal cartridge system? the trick to this is not to have pressure drop.but with modern spin on filters I don't see a problem as long as the lines are sized accordingly.any thoughts? appreciated. |
Lawrence Wolfe
Member Username: larry_from_md
Post Number: 25 Registered: 06-2010
| Posted on Monday, October 18, 2010 - 06:44 pm: |
The power uint i have has a michagana spin on filter on it.Its similar to what you see on the old wisconsons only the return is a small pipe.Lots of theae old filters have a restrictor built into the base,some do not.If you install a new paper replacement your oil preasure goes down if you don't have the restrictor.I have several examples off laying around but never got a picture. |
dmurzic Visitor
| Posted on Tuesday, October 19, 2010 - 11:38 am: |
Lawrence,the old filters had a resrictor? do you mean no by pass valve? or do mean restricted to the size of the hose? |
Lawrence T Wolfe
Post Number: 426 Registered: 07-2003
| Posted on Tuesday, October 19, 2010 - 05:10 pm: |
The restrictor is a small hole in a washer that restricts the flow of oil throught the filter.The hole is about the size of the lead in a pencil maybe a little smaller.Its on the input side of the filter so the filter is NOT preasureized.There is no bypass the oil can flow through the engine so no high psi.will build up if its blocked.There is no way to put a full flow filter on this engine.Your only option is to use the old (partial)bypass filter. |
dmurzic Visitor
| Posted on Wednesday, October 20, 2010 - 11:55 am: |
thanks lawrence,your the first to talk about this old system.could you tell what motor you have? also tell me where the the 1/8" oil line goes from the block to the filter and back to the return.photo would be great.thanks. |
Lawrence T Wolfe
Post Number: 428 Registered: 07-2003
| Posted on Wednesday, October 20, 2010 - 05:19 pm: |
I have a power unit in the next smaller size pistons.The oil line comes out above and to the left of the dipstick, right where the the deep hole is cast into the block.The return is to a hole below and to the right of dipstick, just above the pan.The camera and the one that can post pictures is on vacation.Somewhere i remember seeing a new addon filter kit. |
dmurzic Visitor
| Posted on Thursday, October 21, 2010 - 11:05 am: |
thanks,I see that the oil is coming from one of the galleys and then returns.thank you for the information. |
Lawrence T Wolfe
Post Number: 429 Registered: 07-2003
| Posted on Thursday, October 21, 2010 - 12:10 pm: |
I got some numbers for you.This is a newer filter used on a later engine.Purolator filter base #66650060 and it uses filter NAPA 1050.This filter has the restrictor in the filter its self so each time you replace it you get a new restrictor. This one is newer so you might find it easyer. |
dmurzic Visitor
| Posted on Tuesday, October 26, 2010 - 11:21 am: |
larry,do you know where your pump output is? mine comes directly out the side of the block and then returns to the main galley (center of block)this is where I would put a filter before it re turns to the block.not partial but full flow. |
Lawrence T Wolfe
Post Number: 431 Registered: 07-2003
| Posted on Tuesday, October 26, 2010 - 12:16 pm: |
I have never seen a full flow filter on any of thease engines.That includes marine,tractor, power units and autos. |
Pete Oquist
New member Username: 1955_century_resorter
Post Number: 2 Registered: 08-2010
| Posted on Friday, October 29, 2010 - 03:29 pm: |
Ther is a gentlemen in Alden, MI that designed an oil filter systems for marine engines. His company is called Northwood Boatworks. I have dealt with him and he is honest. He has alot of old engines. |
Robert
Post Number: 385 Registered: 07-2003
| Posted on Saturday, October 30, 2010 - 08:46 pm: |
If you've got a 1/16th restrictor give or take a little, you're perfect for a Frantz filter. Toilet paper is the cheapest filter element there is, also the best. |
greg simmer
| Posted on Friday, November 12, 2010 - 12:04 pm: |
Hi, I'm looking for more information on my Gray Marine Model 70 engine. Horsepower, displacement, etc. The block number is F400A502. Name plate reads M 1955. Thanks, Greg |
Jim Staib
Senior Member Username: drrot
Post Number: 68 Registered: 09-2008
| Posted on Saturday, November 13, 2010 - 07:28 am: |
Model 70 is 70hp 162CID |
gregsimmer Visitor
| Posted on Monday, November 22, 2010 - 04:02 pm: |
Thanks Jim, I appreciate the information. The engine maintenance manual I ordered on line did not specificaaly list the Model 70. |
