Unknown engine at Oxford Museum, Mary...
Old Marine Engine » Unknown Engines - post here with photos » Unknown engine at Oxford Museum, Maryland « Previous Next »
Jeff Greenblatt
Username: jegreenblatt
Posted on Tuesday, October 19, 2010 - 01:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The Oxford Museum (owner of the Kuhner engine) would like your help in identifying this engine, and if possible, estimating its value. Thanks.
Post Number: 1280
Posted on Wednesday, October 20, 2010 - 01:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My best guess is Termatt and Monahan. However there are many look alikes. Detroit, Columbia, Caile and Middleditch to name a few more possibilities.
Value depends on how bad someone wants it. So this being the case it is realy hard to put an exact mumber on.
John Davis
Username: johnny
Post Number: 356
Posted on Thursday, October 21, 2010 - 06:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Jeff,
Do you have any photos from the front of the engine and also the exhaust side? Like Ernie said there are a few engine companies that made this style engine so you have to look the engine over real good in order to try and figure out who made them. You can do a search on this site using Detroit engine works or Termaat & Monahan and find a lot of info & photos. You can also visit my website listed below for info & photos.
http://www.antiquengines.com/Detroit_Engine_Works_Menu.htm
John Davis
Username: johnny
Post Number: 357
Posted on Saturday, October 23, 2010 - 12:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Has anyone every seen a Termaat & Monahan advertisement or engine that had the low pressure fuel injector in place of the carb or mixer? The reason I ask is it appears that this engine has the option on the cylinder but it is plugged due to using the schebler carb. Did Termaat & Monahan use the low pressure fuel injector system on their engines? I have never seen this system on their engines but maybe someone else has?
