Chris Craft K series Alternator conve...
Old Marine Engine » Multi Cylinder Gas Inboards » Chris Craft K series Alternator conversion « Previous Next »
seaskiff
Username: seaskiff
Posted on Sunday, October 03, 2010 - 09:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I need to replace generators with alternators on my Chris Craft cruiser's twin KL's. Does anybody know of an alternator with the same bolt pattern as the generator for a CC KL engine?
drrot
Username: drrot
Post Number: 65
Posted on Monday, October 04, 2010 - 06:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There are no direct bolt on conversions. Someone had made conversion kits and were selling them on EBAY. $700 is hard to swallow tho.
Motorola 12N-MA550 is the easiest to adapt but very hard to find cores. Delco 10SI is readily avaliable in marine with one wire but requires some machining and a wider pulley for the 5L belt.
You can also have the existing generators converted to 12V.
